Title | Size | Downloads |
Layer 2 - LAN Switching Configuration Guide-book.pdf | 2.59 MB |
Click the link on the right to download the complete book.
Preface
The H3C S5800&S5820X documentation set includes 11 configuration guides, which describe the software features for the S5800&S5820X Series Ethernet Switches and guide you through the software configuration procedures. These configuration guides also provide configuration examples to help you apply software features to different network scenarios.
The Layer 2 – LAN Switching Configuration Guide describes LAN switching fundamentals and configuration. It describes how to implement flow control and load sharing, isolate uses in the same VLAN, eliminate Layer 2 loops, divide VLANs, transmit customer network packets through the public network, and modify VLAN tags for packets.
This preface includes:
l Audience
l About the H3C S5800&S5820X Documentation Set
Audience
This documentation set is intended for:
l Network planners
l Field technical support and servicing engineers
l Network administrators working with the S5800 and S5820X series
Document Organization
The Layer 2 – LAN Switching Configuration Guide comprises these parts:
Ethernet Port Configuration |
Loopback Interface and Null Interface Configuration |
MAC Address Table Configuration |
MAC Information Configuration |
Ethernet Link Aggregation Configuration |
Port Isolation Configuration |
MSTP Configuration |
BPDU Tunneling Configuration |
VLAN Configuration |
Isolate-User-VLAN Configuration |
Voice VLAN Configuration |
GVRP Configuration |
QinQ Configuration |
VLAN Mapping Configuration |
LLDP Configuration |
Service Loopback Group Configuration |
Conventions
This section describes the conventions used in this documentation set.
Command conventions
Convention |
Boldface |
italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one. |
[ x | y | ... ] * |
Asterisk marked square brackets enclose optional syntax choices separated by vertical bars, from which you may select multiple choices or none. |
&<1-n> |
Symbols
Convention |
Means reader be extremely careful. Improper operation may cause bodily injury. |
Means reader be careful. Improper operation may cause data loss or damage to equipment. |
Means a complementary description. |
The H3C S5800&S5820X documentation set also includes:
Category |
Documents |
Purposes |
Product description and specifications |
Describe product specifications and benefits. |
Provide an in-depth description of software features and technologies. |
Pluggable module description |
Describes the appearances, features, specifications, installation, and removal of the pluggable 150W power modules available for the products. |
Describes the appearances, features, specifications, installation, and removal of the pluggable 300W power modules available for the products. |
Describes the appearances, features, specifications, installation, and removal of the pluggable 750W power modules available for the products. |
Describes the appearances, features, and specifications of the RPS units available for the products. |
Describes the appearances, specifications, installation, and removal of the pluggable fan modules available for the products. |
Describes the appearance, features, installation, and removal of the pluggable PoE module available for the products. |
S5820X [ S5800 ] Series Ethernet Switches Interface Cards User Manual |
Describes the models, hardware specifications, installation, and removal of the interface cards available for the products. |
Describes the benefits, features, hardware specifications, installation, and removal of the OAP cards available for the products. |
H3C Low End Series Ethernet Switches Pluggable Modules Manual |
Describes the models, appearances, and specifications of the pluggable modules available for the products. |
Power configuration |
S5800-60C-PWR Ethernet Switch Hot Swappable Power Module Ordering Guide |
Guides you through ordering the hot-swappable power modules available for the S5800-60C-PWR switches in different cases. |
Provides the RPS and switch compatibility matrix and RPS cable specifications. |
Hardware installation |
l S5800 Series Ethernet Switches Quick Start l S5820X Series Ethernet Switches Quick Start |
Provides regulatory information and the safety instructions that must be followed during installation. |
Guides you through initial installation and setup procedures to help you quickly set up and use your device with the minimum configuration. |
Provides a complete guide to hardware installation and hardware specifications. |
Pluggable SFP[SFP+][XFP] Transceiver Modules Installation Guide |
Guides you through installing SFP/SFP+/XFP transceiver modules. |
Shows how to install the H3C S5800-60C-PWR and H3C S5820X-28C Ethernet switches. |
Software configuration |
Describe software features and configuration procedures. |
Provide a quick reference to all available commands. |
Operations and maintenance |
Tells how to find the lost password or recover the password when the login password is lost. |
Provide information about the product release, including the version history, hardware and software compatibility matrix, version upgrade information, technical support information, and software upgrading. |
Obtaining Documentation
You can access the most up-to-date H3C product documentation on the World Wide Web at http://www.h3c.com.
Click the links on the top navigation bar to obtain different categories of product documentation:
[Technical Support & Documents > Technical Documents] – Provides hardware installation, software upgrading, and software feature configuration and maintenance documentation.
[Products & Solutions] – Provides information about products and technologies, as well as solutions.
[Technical Support & Documents > Software Download] – Provides the documentation released with the software version.
Documentation Feedback
We appreciate your comments.
